The intent was to have all the AC wiring done by an electrician and get a COES for that part because the AC is the most dangerous.
So from this:
To this:
The main panel was completely rebuilt & a new sub-panel was installed (see pictures below).
View attachment 162632View attachment 162633
So, until batteries arrive and are installed (by me), the Victron Multi's are operating in pass-thru mode.
Given the delays & problems with getting an electrician to actually do the work, it made more sense (to me at least) to order batteries after successful AC install and COES issued.
Electrician has even offered to come back after battery install to ensure correct labeling and wiring. But because any battery install is Prescribed Electrical Work, a COES can probably not be issued for the battery components.
Including the COES, the work cost AU$3300 which was for 2 electricians for 1.5 days including parts (CB's, Distribution Board, Contactor, Wiring) but excluding Victron equipment & the Grid Protection Relay.
If you are planning a Victron install make sure the electrician verifies cable sizes & wiring with you before and as they install as this one undersized the AC Out 2 cable & CB's because he assumed the label on side of Multi was the current limit - but that value does not take account of any Grid Assist Passthru.
