Snapperhead
Hi All..... Finally had my new SkyBox (Not Outback Skybox) installed on the rear studio at the rear of my home. My aim is to eventually go "off-grid" and this is my first step in getting my head around a new area of electronics and exploring how it all plays together. (See Photo's)
The Setup >> Skybox (Sky Energy) Containing:
Multiplus II 48v 8K/110 230v
MPPT RS 450/100 Tr (connected via VE-Direct)
2X BSL LiFePo4 48v 100 Ah 5.12 kWh (connected via CAN-bus) with their own BMS and passive balancing.
Cerbo GX
Victron Energy Meter (ET112) on MCB of house between MPII AC-In <> Grid
14x Kookuburra 415w Panels (5.81 kW)
This is all configured on a rear studio (with sub board x2) that is connected over 50 Metres away via a single cable from Multiplus AC-In to the main switchboard on the house loud bus (See diagram).
Also on the main switchboard is an AC-Coupled GoodWe MS-10kW Inverter (with HomeKit Smart Meter on MCB at grid feed-in point) fed by 18x 440w Jinko Panels (7.92kW).
There is also a Blue Diamond 6.5kVa diesel Gen7S connected as backup on the MCB through a 63A Auto T/fer Switch (See Diagram).
My three(3) Questions to this amazing group are as follows:
1. The Skybox somehow all plays nicely together with the house, except I'm yet to understand or configure the skybox to be able to contribute to the main house loads. (Connected parallel with Multiplus AC-In _ See Diagram) I'm told this is possible and should be happening, however, it's not..... In fact the grid appears to be trickle charging the battery's at night time and also feeding the Multiplus connected AC-Out 1 (Critical Loads) during the night, and not the battery's as planned. The battery's remain 'idle' most of the time, unless the Critical Loads go very high and they then they share the load with the DC-Coupled PV if there is any, and the grid.
2. It's configured with an ESS Assistant, however I don't fully understand all the settings within that Assistant. The mystery "Grid Set Point" appears to do absolutley nothing under any circumstances, however maybe it's not supposed to ? I need some clarity around when and if this 'Set Point' is relevant and when it kicks in. I understand the bi-directionality of it and it's basic purpose, but don't know when it's supposed to work and not work.
3. I'm told that in my current setup, my LiFePo4 batteries will not be able to have or maintain a 'float voltage' and that there will just be one single charge voltage.... that will then absorb for a period of time at a certain current threashold. Is there any way to overide this and have it float at a lower voltage when the battery's are not in use (i.e. small loads with excess DC-Coupled PV energy available) ?
Thanks in anticipation of any advice ?
Cerbo GX
