Velociraptor
- Oct 6, 2021
- 3
I am using my '21 F150 for off-grid camping and I am having trouble re-charging my Ecoflow River Pro portable battery from my truck's onboard power 120v, 2kw outlets. The issue is that I get a ground fault indicator error on the truck's pro power system every time I plug in the Ecoflow River. It charges fine from every outlet around the house, and the truck powers every other appliance rated below 2kw just fine, including a 1500w toaster. The battery only draws about 700w.
My suspicion from others who have encountered ground fault indicator problems with the truck is that it is working as it is designed to when it detects what it believes to be a ground fault, but is simply the result of the thing it's plugged into also having ground fault protection. When you put two things with ground fault detection together in a circuit, one or both of them will trip (that's my naive understanding). So the question is: is there a way to intermediate the connection between these two so that I can avoid the truck's ground fault indicator shutoff and charge the battery from the truck?
E.g. I'm looking for a solution analogous to a GFI transfer switch. Not sure if that makes sense in this case; not sure whether the Ecoflow is floating neutral or bonded neutral, but I know the F150 gas engine is floating neutral and the hybrid engine in bonded neutral. I have the former.
Bit more background context:
Thanks for the help. I would happily accept "consult a qualified electrician" as an answer, I just need to know what to ask them and the language to use.
- My main power source is my Ecoflow River Pro, with 2 100w HQST poly panels - except for short-duration / high wattage applications where I use the truck's 2kw on board generator (blenders, hot water kettles, etc.).
- My typical wh / day are about 350 - mainly from the fridge and from re-charging my computers, so I need to recharge the Ecoflow about every other day.
- Some days I can't wait for the solar recharge, or it's raining, or its night time.
