I’ve built a 24v 2.4kw system that I will be using entirely stand-alone/unbonded for emergency backup, camping, and off-grid homestead setup. The (Xijia) inverter has built-in 8x protection and outlets I’ve run from it are GFCI protected, even though it will be used indoors/protected. The system is setup in an open-faced wooden box. Do I need to add any grounding? I was thinking of running copper from the inverter and charge controller out the box and bonding to the frame of an aluminum hand truck that I’ll soon be adding to move this unit around. Is that even necessary given my expected use? Appreciate any thoughts!
