ShaneC
- Nov 3, 2022
- 151
Hi all,
I am building a shed in the back garden in a couple of weeks, I have purchased 6x415W solar panels for the roof. They will be arranged in a 3S2P configuration. I will be creating a combiner box with fuses, breaker and SPD. In the shed will be the SCC and Inverter, both requiring grounding. On the DC side then there are the panels themselves, SPD, SCC and Inverter that will need to be grounded.
I plan on running backup power from the house that will go through a 2P ATS. My question is can I ground the DC side components to a grounding rod buried by the shed but ground the AC side using the house's earth cable? Given that the ATS I have is only 2P it won't switch earth. Ideally I would just bond earth from the house to the neutral coming from the inverter in the consumer unit, then just the live/neutral would be switched, either coming from the inverter or from the house.
Would bonding earth to another neutral potentially trip the RCD in the main house consumer unit?
Could having two earths, one on the DC side and one on the AC side still leave the potential for a lightning shock to pass through from one to the other?
Alternatively I could ground everything on the shed side to the earth rod, AC included and buy a 3P ATS so that the house circuit never comes into contact with the shed circuit.
Many thanks for any advice given, I've figured out most things through research and searching the forums here but as always grounding seems to be the complex subject.
