adirondack_wanderer
I have an EF Delta 2 Max wired up to solar and powering a few house circuits of 120v-only loads via a Reliance ProTran 2 transfer switch. This allows me to offset some of my electric consumption and reduce my electric bill. Is it ok to have the AC charge port plugged into grid power so if I run out of battery power the unit will use grid power until it charges again via solar? I watched a video about this on YouTube and I saw a commenter say that the AC plug ground prong being connected to the house ground would cause a "grounding loop" thus it should not be connected to the transfer switch when charging and it should not have the AC cable plugged in while feeding the transfer switch. I haven't had any problems so far but thought I'd ask to be sure.
I bought this system to take a plunge into the solar generation adventure because where I live we just get hammered with sun every day even during the winter and I wanted to Make something out of it. If I could go back and do things over I would have done a standalone inverter system like LithiumSolar demonstrates in one of his videos. But I've got this Bluetti unit with extra batteries and just trying to get some ROI on it but I wasn't aware of this ground loop business.
