Mikemills
I have a eco-worthy 5000 W all in one inverter with 4KW solar array with a 200 amp service panel getting power to the receptacles but not usable when I put the tester in just a solid red light comes on I believe it’s the ground The panel box has a solid earth ground rod should I be running a ground off the AC in to a ground rod?
