How big of a generator can you hook to your house? I contest, it is not the watts that is the limit, it is ALWAYS the volts. Watts are not pushed into a device. Watts are drawn in, while volts is another matter. Never, ever, go over on the volts. But that's just my take on things.
And here is another twist; if you have a Pv string that is 220vdc and 7000 watts. Then you split the incoming wire, into 2 and feed one to each pv input of the growatt, than each wire would have the ability to have 7000 watts or just 3500 each?
