Hi all, I purchased the Growatt 12k from signature solar back in 2021 and used the wiring diagram from watts247. Everything looked like it was working fine, used for a little over a hundred days, used about 2600Mwh and a cell went bad. left the system sitting for 2 years, never got to replacing the cell. Finally replaced the cell last month and noticed the system wasn't working how it used to especially when I was charging from solar and the AC through inverter and started reading the forum, learned about the transformer issues, neutral grid imbalance, when using bypass/passthrough mode. Decided to go with the chargeverter as a solution for not having AC input from the grid.
My question is to still be able to use split phase
1. do I still wire neutral and ground from my main panel to load panel and neutral and ground to the growatt inverter (according to the diagram from watts247)
2. neutral and ground from main panel to load panel but no neutral to growatt inverter. still wire ground to inverter.
3. don't know if the inverter itself creates neutral for split phase, if it does, would it be neutral from inverter to load panel, ground to load panel and inverter from main panel.
chargeverter will turn on through contactor triggered by low voltage and just help the battery maintain loads til morning and solar kicks in.
Thank you for any input!
