Hi all,
Same issue going on here. 3x SPF5000ES in parallel with 4x 4.8kW Growatt Hope batteries (19.2kW total).
Approx 4.5kW of solar connected to each inverter for a total of 12.8kW in panels.
Charging starts off limiting each inverter to 21A (total 64A to the batteries). It stays that way until around 95% SOC when it raises to 61A per inverter (total 185A to batteries).
As such, a lot of the day's solar is going to waste and it means adding additional capacity in batteries will be wasted, as they will never charge during the day.
I have been talking to Growatt technical for the last month, and it seems they don't even understand their own system.
Also I have noted that the batteries only operate between roughly 46.5V when low, and 51.5V at a high SOC. There is little to no voltage drop between the inverters to the batteries.
It's getting frustrating not getting a clear response from Growatt as I purchased the system based on their advertised performance specifications.
Any help appreciated.
Anthony.
