Jim Burrow
- Jun 27, 2020
- 516
Is anyone using the Growatt 5000W Solar Hybrid Inverter 230Vac, All-in-One Pure Sine Wave Inverter with 100A MPPT Controller? If so do you have a PDF for that I can have a copy of or a link to where I can get it?
The best I can tell, it only takes 220vac for a Utility connection and will only out 220vac to the load. What good is this controller if you can not connect it to your home as everything in the home runs of 120vac except the air conditioner?
I'm presently running the MTTP 2424lv-pip controller/inverter but running into it shutting off problems for 30 to 40 seconds before auto-restart. And I would like to have more power available than the 2.3Kw of the 2424lv.
