Hi, Spanish Flyer, MajicDiver and others that might be able to help.
BTW, I am also in Spain.
I (foolishly I think) decided to forego learning too much about solar and let my installer come up with a quotation. Based on a desire to zero my electricity bill (like MajicDiver) my only two requests were that it should include a 10Kw solar array and that I should be able to add batteries at a later date. He came up with a quote for the panels, etc., two Growatt MIN 5000TL-XH inverters, two breaker boxes (one for each inverter AC circuit), running to an Eastron 230Modbus smart meter, which then connects to the house load and the grid meter. I went ahead and this was completed in March 2022. Once I finally got an ethernet cable up to the solar hut in November, I was able to confirm that the system is operating reasonably well.
To cut to the chase and because the price of electricity in Spain is now around 50 cents (inclusive of VAT) a KWh, I decided I wanted batteries this autumn. So I called Autosolar en Valencia on the phone and they told me that I needed their there ARK 2.5H-A1 HV batteries and BMS, and I bought three 2.5 KWh modules and the BMS. However, I was then informed by Growatt aftersales service in Spain that their ARK 2.5H-A1 HV and BMS would not work because I have two inverters not one, even if I only connect the Growatt battery bank to one of the inverters. It's all been a bit of a shock to me. I thought this would just be plug and play, but now I'm starting to get an idea of the state of play (steep learning curve! I am not a born electrician or engineer by any means).
Since I do not want to spend a fortune changing the inverters and the battery bank and I no longer trust the installer (I had to connect the comms from the smart meter and change the baud rate), I would very much appreciate you letting me know if there is another solution to this problem, or confirming that the solutions I have gleaned from other sources are viable.
One solution sent to me schematically (not a wiring diagram) by one of the staff at the shop is attached.
Another solution that I thought if myself is to split the inverters by having two separate Eastron 230Modbus smart meters which I assume would enable me to have two separate plants on the ShinePhone app that I could just add up to monitor the system, but I do not have a clue as to whether this would work.
Please let me know what you think if you think you can help me to clear up some concepts here. The inverters are great and so simple. Additionally the idea suggested by Majicdiver I may be able to add any batteries I want as long as they add up to the equivalent voltage and amperage of the Growatt modules and do not exceed the 7 units advised by Growatt is very promising. Majicdiver, please tell me more!
