MajicDiver
I don’t see how it could break anything trying, wire it up with a breaker between them and a clamp on amp meter so you can see what happens. Note that I was talking about the MIN-TL-XH-US inverter, the one in your drawing is the European version. I’ll probably try it this fall when it is nice mild temperature and put a 16 amp breaker between them. What ever the result is would be useful learning.What do you think will happen if I connect Growatt hybrid inverters with separate AC loads through DC battery out (drawing below)?
