so in the ongoing conversation with Growatt this is the latest response.
Hello George,
The system for US2 is working as needed. As the lithium battery without a BMS, if you need to use solar power during the battery voltage is full, please ask the battery supplier to integrate the BMS of the inverter into the battery to make sure the BMS of the battery is compatible with the inverter.
Best
Kevin L
I would note that in my multiple responses they are aware that the system batteries have Overkill Solar BMS. Now that's probably not what they want as I have no way of knowing if overkill solar BMS (
https://www.resacs.cz/user/related_files/8s-100a-6.pdf) will integrate with or communicate with the Growatt. I suspect not at this time. Who knows about the future. But I would also note - at no time have they challenged my observations or understanding of the US2 settings impact (solar power clipping off as batteries reach a full charge as indicated by setting 19).
I'm not terribly sure what else to do other than use setting USE since it appears to work. hopefully it isn't doing any damage to the LifePo4 cells - I don't know how it could be but I'm not a solar or battery engineer. The BMS' are not locking the battery down IE they are not going overvolt on cells or pack. And at least seemingly the unit charges the batteries and then powers the load from the panels if in use mode. You know like you'd expect a solar inverter to do. Not so much in us2 (which Growatt tech seems to be intent on us using). I mean if the thing is just going to shut off the solar in the middle of the day isn't it really just a acting like a solar Charge controller and a battery powered inverter in one box.. a solar inverter that shuts off solar panels halfway through the day is not, in my opinion, very useful. I would be interested if this behavior is seen in any of the other "all in one" s...
