I got the data from Chins directly. I have attached a pic of the info they sent me. I have the Growatt 3k 48v version setup by these settings as per recommendations. The chart you attached to your post seems pretty accurate but not sure if it applies to specific batteries. The ones I use are the standard 100ah LiPo4 batteries that they manufacture, which in my opinion are a good choice for the price. Performance wise I have to give them credit, during their capacity test I was able to get 110ah from each one of them. I do have questions about their recommended settings. I find that the low voltage cut off is kind of high, don't it? I guess that would depend on the BMS specs. The Growatt manual says 42v should be the cutoff and Chins says 46.4v which seems high to me, but then again Growatt might be talking about some other type of batteries that the BMS is set to 42v before disconnecting the battery to avoid possible issues. The one issue that bugs me is that by setting a float voltage on the Growatt the inverter will keep the charge level at the float charge, which is by design, but in my case I use the inverter to supplement the 3 ton house unit that sucks around 25-30kw of energy a day, during Summer. I also noticed that when the batteries reach float the inverter starts supplying power with the batteries even though I have it setup to use PV energy as priority, once the batteries reach above float it switches back to PV. Any comments on that? why does it uses battery power when PV power is available, maybe clouds going over? I do have an Enphase IQ PV 5kw system but is grid tied so if power goes out that's it. By doing so I can trim the 3 tons consumption by 5kw per day which I think is worth it, since is a 2 story house it keeps the upstairs cooler too. I use a small split unit from 9:00 AM til 6:00 PM when temps start going down, this is Texas and in the Summer temps hover around high 90s and some days up to 105F like last month, temps went above 105F and the power went out several times. While everyone was out of power I was brewing coffee and stuff! But anyways, when the batteries drop down below float charge the relays start clicking I guess is charging while discharging (when running loads) not sure if the the Growatt switch from charger to inverter modes in specific cycle or sequence. anyways ant tips or questions would be highly appreciated! I'm trying to learn how This Growatt works in great detail and hopefully to understand it better! Overall I like it so far, I just hope it last to recoup the investment at least, I will see!
