I currently have 4 of these units
When I setup 2 totally separate systems like this everything works perfectly no light flickering no imbalances
However, Once I reconfigure them in one large system like below, I see really bad light flickering, and if the load imbalance between phases goes more than about 1500 watts the whole system will cut power to the inverters, reset and start up again. Same issues with this when I connect the grid on each inverter, as well as when I set it up totally off grid.
I've talked to Signature Solar where I purchased them, and they've attempted to help, they had me check for ground loops,which i didn't find. I checked that by disconnecting every circuit from the breaker box, and checking continuity from neutral to the ground wire, as well as neutral to a grounded pipe in the house.
I've also put these inverters into every other mode possible, and it seems to be only split phase with 4 inverters that causes the issue.
Two separate 120v systems with 6000w each worked fine
One large 120v system of 12000w no issues
Any suggestions any of you can provide would be helpful and I thank you all in advance. this community is amazing!
