joshuaodell
- Feb 21, 2021
- 2
I've been comparing these 2 inverters, trying to decide on one and I was wondering if anyone else had done the same comparison. From what I can see the differences are mostly in the PV input voltage (150 vs 250). I'm going to be running a very small array <1kw, so I can structure the panels to fit either, and really the smaller voltage would probably work better. But, the -es looks newer, and possibly has more benefits that aren't mentioned on the spec sheet.
SPF 3000TL LVM
SPF 3000TL LVM-ES
It looks like Will has the -es in hand to review, but I need to pull the trigger within the next couple weeks. Any thoughts on which is better at this point. I'll be <1kw panels, and probably 2 of the Gyll 5kwa rack mount batteries. It'll power a small shed with computer, and a very small minisplit (600 watt) run occasionally.
I'd also consider that Renogy, the higher efficiency looks appealing, but people seem so happy with the Growatts that it's hard to ignore.
Renogy 3500
I guess what I really need is Will's comparison to come out sooner then he'll realistically be able to put it together.
Thanks in advance for any comments.
SPF 3000TL LVM
SPF 3000TL LVM-ES
Renogy 3500
