JLBinTN
I've been using the Growatt SPF3000TL LVM-48P Inverter in my offgrid system for several months now, and for the most part I've been very happy with its performance. Two things I'm not happy about:
1/ No way to pass AC directly through inverter to power loads. I'd like to run my RV AC off my 3600W generator from time to time, but can't because the Growatt insists on charging the battery as first priority. I've monkeyed around with different settings, but haven't found a way around this. Can't get it to work even when the battery is "full" and the charger is supposedly off. For now, I have to go outside and physically unplug the Inverter from the generator and then plug the RV into the generator. Not that big a deal, except when it's 2AM, 85 degrees in the RV, and the battery is low.
2/ Using PV for input power (with the Growatt set to "Li" for setting (05), and connected to the LiFePower4 battery using the RJ45 cable) results in the battery cycling between 91% and 88% (roughly) capacity. When the battery reaches 91% capacity, the charger turns off, the PV panels stop providing input power, and the Growatt pulls from the battery to power loads until the battery drops down to 88% capacity. At that point, the charger turns back on and the PV panels begin providing power again. The result is a fair amount of PV power "left on the table" and unnecessary cycling of the LiFePower4 battery.
What *should* happen is that the charger should turn off at 91%, and the PV panels should continue to provide power to the loads as applicable. In the event that PV becomes inadequate (a cloud passes over for instance), the battery should augment solar and make up the deficit. Once the battery drops to a predetermined charge level (88%, or user-defined), then the battery should begin charging again until it reaches a full charge. This should be an easy software fix. Or perhaps there is a setting to control this that I am unaware of?
I'm considering ditching the "all-in-one" and going back to individual components. I feel like I'll have more flexibility and control of the system. I could be wrong though.
