radiomean
- Aug 17, 2022
- 83
Hi, I have a Growatt SPH 5000 and a Growatt Battery GBLI 6532. I have been on the Octopus Intelligent tariff (10p per kWh for 6 hours overnight) for a month and of course, if my battery is low or not charged I can set the SPH 5000 to charge the battery from the grid at the low 10p rate and effectively have 6 kWh of 10p electricity to use in the day...
However when I look in the Growatt Shine server program (in the section 'devices - settings'), there are the usual dire warnings 'only authorised people to modify these settings' and 'it's on your risk if you break this' ... I've screen shotted the relevant section (attached) and would appreciate advice to confirm that the battery will charge from the grid using time slot 1, from 0200 to 0400? And hopefully will charge normally from the Solar PV normally at other times...
Also, I think the 'key to save' (password) is just Growatt25032023 (Growatt and today's date?)
Thanks!
Thanks!
