Got an opinion of whats best among the brands? The all in one and good prices are attractive. Do they last a decent while and can they be serviced?I have not seen any re-branded Growatt inverters. Sacolar is a division of Growatt but the inverters/products are different.
Most of the rebranded hybrids on the market that I have seen are SRNE, Sacolar or some variety of Voltronic. MPP Solar is Voltronic. The Renogy is SRNE. It's an old model SRNE doesn't make anymore and marked up a bit as well (I can get them factory direct).
This is a lot of food for thought.From my point of view as an installer, several things trouble me with that particular inverter.
1. They offer spare parts and it only comes with a 2-year manufacturer warranty? This just spells problems. They are expecting failure. The average tier-1 inverters are a minimum of a 5-year warranty generally. Some are 10 and 15 years. The SMA 6048 inverters have a 10-year standard warranty out of the gate.
2. It's clear to me that there is 99% chance they are using an EI transformer and not a toroid so there will be more losses and EMF radiation than there needs to be.
3. 7000W PV input for a 12KW inverter? Why? This simply makes no sense.
4. 250V is better than 145V shown on the datasheet for sure but realistically wiring in your case 20KW of PV at anything less than 400V-600V IMHO is just a nightmare. Plus the higher the string voltage, the more resistance it can overcome with connections etc as the system ages.
5. It's only marginally less than what I can get a 12KW Deye for before shipping.
6. I installed non-IP65 rated inverters but it's my preference not to. The less the boards are exposed to the elements (dust on the components pulled through the vents), the longer they last. SMA 6048 inverters are not IP65 but they are airtight when closed, keeping the boards pristine and untouched by the environment for the foreseeable future. Deye inverters are actually IP65 so they are good even installed outside.
7. Bottom line, this inverter feels "slapped together" with a bunch of parts from here and there. Not a tightly integrated machine designed from the ground up to last.
If you're looking to install 20KW of panels, I would look at PV inverters combined with bi-directional battery inverters and/or 500-600V hybrids for sure.
Yeah and I expect worse than that. When clients ask me about cheap inverters, I gently mention that this is powering everything they own so the results could be shortened life on their refrigerator compressor etc. The effects of a low-quality output cascade.2. Consider the cost of solar, I won't get to upset about a little inverter efficiency but when I look at the specs the THD is kind of high for a pure sine unit. They list 10%.
I suppose I was mostly talking about the number of strings to install/track. One string per MPPT is ideal for the greatest power output which is one reason why longer strings work extremely well.3. My current system uses a lot of #4 wire, so nightmares don't bother me. I get a little uncomfortable with super high dc voltage. I prefer to stick to around 120-150 volts. I've also read a lot of stories about 400-600 volt systems catching on fire from the high voltage getting through insulation. Its also hard and expensive to source DC breakers and fuses of that voltage.
I'll PM you.5. How much does a Deye inverter go for?
Super.6. Good to know about the dust. I will install a filter in the inverter room if I end up with a non sealed inverter. I think some of the outbacks might be sealed as well.
This is my preference as well. I prefer 5 - 5KVA Victron units over a single 15KVA any day. Now, the issues there are needing to be very precise with the wiring but it's straightforward with appropriate training.7. I will keep my eye out. I like units that support paralleling. In case one goes out I have a back up.
That's super to hear. I tell clients that if properly taken care of, components and lead can last 15-20+ years. We have a saying among installers: "Batteries don't die, they're murdered". Proper charging and proper maintenance is key to making them last.My current system is a 24 volt system. 4000 watt magnum inverter, two midnite classic charge controllers and 4000 watts of solar.
I like the low frequency inverter chargers. Its a useful feature and it has great starting capacity. I have 24 volts of trojan l16 H-AC batteries, two sets for 435x2. Just over 20k Watt hours. Almost 13 years old and showing some age but still working.
What size are you looking for? What kind of pricing are you seeing for the ones you're looking at?My upside is a I have free natural gas but reliable and correctly sized generators are hard to find and the good ones can cost more than most of my solar system! I need one under 10k and hopefully 1800 rpm with parts available. I have yet to find something that fits that.
I am looking for something in the 5-9 KW rating and hopefully 1800 rpm with common parts so likely an industrial car engine like those chevy engine. At this point I am half tempted to build my own. My grandfather rebuilds volkswagen engines for aircraft. He said I can have a rebuilt 40 HP motor for free. Parts are available and they are about as mechanically simple as you can get and reliable. I could belt drive it at 1200-1500 rpm and it should last a LONG time. Figuring out a proper governor might be an issue though. They have a history of ground power units.Yeah most of the Tier-1 inverters are 5 with the option to extend.
I don't recommend breakers for HV strings. Typically on the internet DIN fuse holders & fuses are low-cost and plentiful. We don't have any issues and I would say by and large the majority of installers don't assuming a proper installation with the correct PV wire and tight MC4's etc. Most of what I see is a lack of engineering when laying the wiring on a roof/mount, resulting in mechanical wear in places there shouldn't be any. Conduit and flex tubing is the solution for this generally. Mounting connecting MC4's directly on a terminating weather-proof IP65 enclosure, with a conduit run back to the disconnect/combiner/PV inverter. Every installation requires something different, this is just what I see.
I'll PM you.
Super.
Can you get the “US” split phase hybrid models?Deye has some new units rolling out. I need to get pricing on them yet and they require an auto-transformer.
