whereitsat42
Had an idea: the max current my panels can produce is 150A, and instead of buying a charge controller rated that high, I thought I could use equipment already on hand in a layered approach, by using bus bars to split the incoming charge between three lower rated charge controllers, then rejoin the lines at the main bus bar, as detailed in my included, high-end artwork. Would this work and is it safe? And would I need wiring that supports the full 150A on the entire charging side (1 AWG basically) or can I get away with connecting the charge controllers with a gauge that supports up to each of their respective max supported currents?
Notes: No, switching to 48v is not an option at this time. Yes, I am appropriately fusing everything and just didn't want to clutter the picture up by including them.
