Interesting thought experiment. Gain does not justify the time and expense, thinking.
Maybe you have some relative or friend with a desire to try something new and has ability with climbing equipment. Attach safety near top, use a quality pruning saw (not chainsaw; I have a battery powered Stihl with 10” bar[?], it is too crazy unsafe in a tree) and remove limbs starting at the lowest level needed to give more afternoon light to the panels, then continue up to the top. Falling branches will get stuck on intact branches, that will be tricky but shaking or prodding will do it. Just keep cherished beings away.
Can you open burn with a permit in your location? Can you rent a wood chipper? Can you use a bunch of mulch?
If your goal is to remove the entire tree eventually, attach safety near top and start cutting the lowest branches first then working up. When a meth eschewing arborist is working in your area, see if he will let you piggy back your tree trunk removal into his existing job.
Hopefully the time and expense of me writing this is of some worth to someone some day. I would do that job, but I like heights.
