sunshine_eggo
Happy Breffast!
I would hit the reset under the conditions I mentioned, cells above 3.40V and charge current < 8A. You know it's within 5%.
Thank you… yes, I tried to charge this one to 13.8 just like before. It trips the fault. Today I will drop that to 13.7 and try again
what do I say to this seller? They claim my systems is causing this because “we sell hundreds of these and have never had a problem before”. I cannot see how I could cause one battery to be below capacity and so causing it to overcharge near max volts. But, I could be wrong. Any ideas?
I think it is possible that this problem exists with many of their batteries…but because they sell them without the Daly BMS, the people (mostly EV owners) don’t know it is happening. Possible?
My understanding is that overcharging that one battery will slowly drag the entire pack down and shorten the life of the whole battery….is that correct?
If so, then people who do not know it is happening would just have to replace it in a few short years and wonder why they didn’t get the cycles they should, Does that sound like solid reasoning?
The seller tells me that this Daly BMS does NOT do active balancing. Something you were sure of from the start. I guess they do now have an active balancer…but, there just isn’t anyway I am taking this apart to try to install…(get the wires on each cell).
so what is the long term effect of charging only 13.7. Or…more important..tripping that fault alarm all the time with one cell over charging? I thought it would result in shortened battery life. So, if you never knew this was happening and you continued to charge to 14.2 each day…you would have a shorter battery life and never know the reason…?
Brought the MPPT up to 13.7 bulk. No fault alarm, all batts within .001 of each other.
MPPT tripped into absorb. After 2 hours I see the delta v is .014 and climbing. Up to .016 pretty quick.
I turned off charging.
battery monitor says SOC is 97.4%. That is mostly likely plenty for my needs…but I am still feeling I cannot allow charging to happen when I am away from the rig.
I am thinking to drop the absorption time to just that 2 hours.
Aside from the pita, can I accept this situation?
Can I find an inverter/charger that is programmable like the MPPT? (My Renogy does 14.2 in bulk…period…).
What is the long term effect of hitting this overcharge On a daily basis.?
