I removed a nat gas boiler last winter, replaced with electric water heater as buffer tank, resistance heating only. Main heat when we're home is woodstove, so we only were spending $3-400 annually for gas. But last winter we replaced that heating load with grid banked electric which was all free. This year I set up an ASHP for A/C and heat to the air handler, and just now getting a refrigerant to water coil connected to the hydronic system. So this winter we should get on the order of 2-3x the heat for the same banked electricity, and need to burn some less wood. Free heat is great. But it's still probably not enough total heat. More solar in the future!!! There's more room on the roof, and I could improve the location of a ground mount and add tracking to it.
All that said, the cost for the heatpump system is not going to pay back with only $3-400 annual savings. I don't care, we'll get the 30% ftc for the heatpump, and DIYing it was pretty reasonable, around $7k, it will come out just about where the credit maxes out.
