Tiktaalik
- Apr 3, 2021
- 46
Newbie here and I just order a set of 20 Lishen 272Ah LiFePO4 cells two build two separate battery configurations. One will be a 12v - 4S (4 x 3.2v cells) bank and the other will be a 24v - 8S2P (16 x 3.2v) 544Ah bank. I am looking at buying a Heltec BMS for each of these systems. Would the two with the red checkmarks in the attached image work? I'm not sure what the difference is between all these and what I ought to be looking for. Is it possible to use one BMS for all 16 cells of the 8S2P config or do I need two BMS units? Do I need a Smart BMS? Thank you!
