Hello,
I am new here and new to solar systems. I have an engineering background and decent basics in electricity. I am from Belgium but I live in the Philippines (single phase 240V, 60Hz). Our electricity provider is expensive, unreliable and does NOT offer net metering. We experience blackouts for several hours almost every day. I have a diesel generator (shared with the neighbouring houses) but electricity from the generator is even more expensive than from the provider.
I am consuming about 750kWh per month. Most of the consumption happens at night when I run my 1.5HP inverter AC (runs almost only at night, could be 9pm to 5am or midnight to 8am). Other major loads are a 1HP inverter AC in the second bedroom (almost never runs), a 2500 W water heater, washing machine, dryer (rarely used), two 1/2HP pumps for my water system, hot and cold water dispenser, inverter ref/freezer, electric oven, fans, chargers, laptops, vacuum cleaner, hair dryer, CCTV system etc. I have south-oriented roof space for about 5kW of solar panels.
My goal is to minimize my electricity and diesel bills. Note that the generator is running anyway for the neighbours when there is a blackout from the supplier. There is however a few minutes between the start of the blackout and the startup of the generator.
My plan is as follows (please comment as you see fit):
- install about 5kW worth of 545W solar panels on my roof
- get a 8kW MPP Solar / EG4 / PowMR / Anern / PowLand / Chinese clone inverter - I am very open to recommendations for my application
- purchase 30kWh worth of LiFePO4 batteries (pre-built packs or build the packs myself) - also very open to recommendations for pre-built packs and/or cells + BMS
Questions:
- correct me if I am wrong, but I think I need the MPPT in the inverter needs to be at least 104 Amps to make to best of the 5kW solar array (5000W / 48V = 104A)?- reason I am asking is that I see some 8kW inverters with only 80 Amps MPPT...
- are MPP Solar / EG4 / PowMR / Anern / PowLand / SunGold / Rich Solar etc all rebranded clones of the same equipment? Or are there differences in the components etc? Looking at the manuals, the software certainly looks to be the same between the brands
- would I be better off with a Sol-Ark? I won't be doing grid export but is it really the only difference between the Sol-Ark and "normal" inverters of equivalent power? The price difference is so enormous, there must be something else to it?
- has anyone been able to establish battery comms with a MPP Solar-like inverter, if using self-built battery packs, say with a Daly BMS or chinese-built packs? I see that the software has comms presets for some well-known brands. Are these presets usable with some different BMS or pre-built packs?
- without battery comms to the inverter, how can I be alerted remotely that one of the BMS / packs has tripped?
