With the rates you pay compared to us in the Midwest @ $0.12-$0.14 KWH I can understand why they get all bent out of shape. When I pulled my smart meter it took the power company about 30 minutes before they called and asked if I needed a lineman to come out to check my power outage. I told them we were changing out a bad main breaker and that was the end of story.Depends on local regulations. That's not allowed here and has lead to some Kafka-esque horror stories proving that it was not done with intend to defraud (IE breaking the tamper-evident seal and creating a gap in the smart meter telemetry)
These are some great points for me to think about.I think you can fit most of the production from 12kW of PV panels within 120% rule, no need to reduce breaker size.
I think these smart meters are able to remotely shut off the power, so requesting same day turn off/on is not that much overhead for the POCO.With the rates you pay compared to us in the Midwest @ $0.12-$0.14 KWH I can understand why they get all bent out of shape. When I pulled my smart meter it took the power company about 30 minutes before they called and asked if I needed a lineman to come out to check my power outage. I told them we were changing out a bad main breaker and that was the end of story.
I have to say I was surprised they called.
Have you contacted your AHJ and POCO to see what they allow? Or if you can't get visibility from someone within the same POCO I recommend posting on r/solar to see if there are any nibbles.But I do need to ensure I'd pass inspection with my backfeed solution. Attached are some pics of possible layouts and the actual roofs.
If there are any trees/shading, half-cut cells will go a long way (theoretically) towards preventing bypass diodes from being picked.Shadows over a panel are to be avoided when others in the string get direct sun, produce full current. Can burn up bypass diodes.
Sure. The parallel connections reduce the number of scenarios where an optimal tracker will activate a bypass diode.Half-cut cell panels are just an array of 2p3s panels with 3 bypass diodes.
My county follows 2018 NFPA1, so I need to check on how that impacts my roof space for the panel layout. My AHJ is not very responsive but I'll give them a try.Sounds like a 7.7kW inverter would be a reasonable choice.
I see your picture considers setback from eaves, and walkways. Those rules have evolved, so make sure based on current rules.
Some places, the eaves count as walkway, others walkway must be inside walls.
Shadows over a panel are to be avoided when others in the string get direct sun.
Is that tree to the South? How is sun exposure for different times of day and seasons? It seems to be your biggest problem.
Have you looked at the trend of power prices in your area?I don't plan to do any battery system.
In Maryland (where I am) the POCO's are required to pay the same rate they charge for the net metering. I haven't heard of POCO's ripping people of with net metering but sounds like I should do a little more homework.If no battery, microinverters may deal best with shade.
But you're planning on net metering, and if there's anything you can count on, it is that regulators will pull the rug out from under you.
Are you required to have RSD? That would mean smaller additional cost for optimizers or for microinverters.
Rip off means the rules change. Whether wholescale or by changing the rate plan.I haven't heard of POCO's ripping people of with net metering but sounds like I should do a little more homework.
It is not, and there are two Tigo communications methods. One that is like sunspec but not compatible (in my headcanon it’s due to their lawsuit with sunspec)Tigo may not be exactly SunSpec.
Indiana is still on NEC 2008, still a few places on NEC 2014 as well. (Not necessarily relevant to this thread)I would be surprised if there’s that many AHJ where module level RSD for rooftop is optional. I believe that came in with NEC2017. Long time ago
