I need to run one string from my exterior garage to grid tie/hybrid inverter. ((((The other 3 strings will be running from the home's roof. The inverter allows for 4 strings/DC inputs. The panels on the house that compile the 3 strings all face due South, which is fine; each of those 3 strings will get equal sun and will NOT require optimizers.))) However, the fourth string on the exterior garage will comprise half the panels or 8 panels on one side of the roof's garage and half or 8 panels on the other side. The roof's gable faces due South, so both sides of panels of the garage will get equal sun in the middle of the day. But only half the panels will get sun in the morning, and the other half will get the sun toward the evening. What is the solution to this problem of unequal sun in parts of the day if the garage panels are all on the same string? Is it possible to use optimizers on one string, but not the other 3? I was planning on running all 4 strings in series. Would it be better to somehow ONLY run the garage string in parallel? I would appreciate the help of any knowledgeable people out there. It's going to take 70 ft of wire to run to the panels from the inverter. Each of the 16 panels have a current of 8.97A & 37.33V at max power.
