I would not float lithium at the same voltage as absorb unless your use case is a home or similar environment which has loads and you are charging from solar. 3.35 is very close to the voltage in which the cells settle at at might not trigger balancing. I charge my EVE cells to 3.40 volts with a long absorb time. I only charge from solar. My inverter does not have a setting for Float when I choose Lithium profile.
