Wildcat1978
Ecoflow delta pro:
2 base units 2 add on batteries 2 Ecoflow smart generators dual hub connected to simple 10 circuit generator backup box.
I want to add solar to power these circuits as much as possible. I have purchased 4-450 watt panels (2 for each ecoflow) and 2 solar trackers.
Problems:
300 foot wiring run to ideal spot for solar panels to Ecoflow delta pros.
Questions:
What gauge of pv wire to use and can I bring it to the Ecoflow delta pros on a set of wires (instead of 4 saving alot of $$$) and then split it up to connect to the Ecoflow delta pros solar chargers??
Any ideas on how to most efficiently complete this system is greatly appreciated!!!
Problems:
Questions:
