Hey JRam, can you provide a little detail about the switch to turn on/off the inverter of the Growatt that you mention? I am just starting plannning/build of a 24v system, and have a Growatt 3000TL on backorder (they are currently stuck in LAX and supposed to be here by beginning of May).
Since it's an all in one, how does that work exactly?
Backgrounf of what I'm doing here (optional read):
I'm graduating from using x2 6v series-connected Trojan Golf Cart batteries topped off by a 100 watt suitcase panel w/cheapy pwm controller, plugged into a Zamp outlet ( had to reverse the wiring on the Anderson connector--that's how Zamp makes itself prorietary, LOL) to a 24 v battery bank composed of x4 12v 100 ah Battle Born LifePo4s in series-parallel. Planning to have 800 watt solar array on rooftop of a TT you cannot walk on the roof of---good times! I'm definitely drinking from the fire hydrant here. I know I can make it work, just nervous that first trip is this Memorial Day Weekend.
Any advice is greatly appreciated!
Holly
