Don't they have anything closer?So, the 70 amp victron buck would then be the appropriate model based on the WFCO amperage rating of 35 amps?
I'm looking at this one, but scratching my head as to how it connects to the panel. It says "Double faston tabs 6.3mm". I'm guessing it would require getting the appropriate terminals and attaching them to the wires.So, the 70 amp victron buck would then be the appropriate model based on the WFCO amperage rating of 35 amps?
Just to be clear is THIS the unit you're talking about? Also is there any reason this would not work with a 30amp WFCO?I was looking at that particular model before buying the 70amp version. I just didn't like the spade connectors so I went with the non isolated version with the screw terminals. You can find a 40amp version with screw terminals in other websites, not sure why Amazon doesn't sell it.
To connect it to the panel all you do is connect the positive of 12v output to the DC distribution board (board with blade fuses) and the negative to the negative bus bar.
That is a top shelf dc2dc converter.Just to be clear is THIS the unit you're talking about? Also is there any reason this would not work with a 30amp WFCO?
My understanding is limited, but wouldn't the buck convertor @ 70 amps handle more 12v volt loads if i needed to add them in the future, or is that not how it works.
Since I also have a 12 volt pack, with a much larger 24, I use the 25 amp version of that DC-DC. My actual 12 volt DC needs in my RV are pretty low.. I liked the 25 amp model because I could parallel another if needed and it has 96% efficiency. More than the others.Yes that is the unit I was talking about. Victron makes a similar 40amp version and is of course cheaper than the 70amp version.
Sure the 70 amp version can future proof in case you need to add more loads, keep in mind you will have to replace the DC fuse block for a higher rated when that happens.
same experience here,Since I also have a 12 volt pack, with a much larger 24, I use the 25 amp version of that DC-DC. My actual 12 volt DC needs in my RV are pretty low.. I liked the 25 amp model because I could parallel another if needed and it has 96% efficiency. More than the others.
For what it's worth, I chose a 100A 24v to 13.8v converter. I designed my travel trailer to have adjustable height suspension so I needed a high duty cycle OBA compressor. 13.8v is closer to the DC output of a car with its engine on, which is why I picked that over 12v.Get a Victron Orion 24/12 instead of those cheap Chinese converters. Big heatsink, fan and adjustable output voltage. Plus you are not limited to the small wires that come with the cheap converters.
I think many buy one too small.For what it's worth, I chose a 100A 24v to 13.8v converter. I designed my travel trailer to have adjustable height suspension so I needed a high duty cycle OBA compressor. 13.8v is closer to the DC output of a car with its engine on, which is why I picked that over 12v.
The converter has no active cooling so I'll heed the warnings and add a couple of fans to it. Heat is probably what kills the cheaper Chinese buck converters.
Part of the issue is grounding. If you run thru the Growatt transfer switch, it will automatically ground to shore power when connected and transfer switch is closed. Unplug from shore power and run off battery/solar, the unit grounds to the inverter automatically.Great discussion on this thread. Why wouldn't you use the existing RV wiring and mimic the shore power to Growatt connection for an AC out to our distribution panel? Keep the AC/DC converter to power your DC loads? I've posted a drawing, what am I missing? I omitted all the line fuses etc I know but the question here is why not utilize the RV's existing wiring?
Isn't that the inherit switching functionality of the hybrid inverter? What's the grounding issue then? I don't see this any different than a standard install when shore power is out and so the inverter switches to solar/battery only. What am I missing?Part of the issue is grounding. If you run thru the Growatt transfer switch, it will automatically ground to shore power when connected and transfer switch is closed. Unplug from shore power and run off battery/solar, the unit grounds to the inverter automatically.
Not all inverters have the switching ability. Start with these examples. https://diysolarforum.com/threads/how-does-your-inverter-deal-with-ground.17138/Isn't that the inherit switching functionality of the hybrid inverter? What's the grounding issue then? I don't see this any different than a standard install when shore power is out and so the inverter switches to solar/battery only. What am I missing?
if i had to guess invested so far about 5k with the batteries being the biggest expense. I added 2x more batteries and panels to my original designHey Chmiko, thanks for the informative thread. How much do you have invested in the system?
