Help with wire for 18kpv
Packen
I am installing my 18kpv (upgrading from 2 6500s), what should I use for the service wire from the meter to the inverter and then from the inverter to the 200amp panel? I have 4/0 aluminum but was wondering if there was something else a little easier to work with. This stuff is hard to maneuver around the corners in my conduit.
Using DLO or Welding cable in place of building wire is kind of a murky area of the code and somewhat dependent on the local AHJ. Some DLO cable may have dual ratings on the insulation from what I've read.
From a practical view point a 3/0 copper, fine strand cable would most likely solve your problem but then the mechanical lug may not be rated for that type of cable. If it was at my house, I would be comfortable giving it a try but would make sure to re-torque the mechanical lugs a few times over a 24 hr period then periodically to verify they are not getting loose or creating heat.
4/0 aluminum is the recommended service feeder.
3/0 copper would also work, but it is MUCH harder to feed.
You could also run a pair of 2/0Al but I wouldnt...
If you order some 600V rated multistrand 3/0 copper it may work easier, but cost a lot more.
What size conduit and how many 90s do you have?
Are you trying to run SER in conduit?
Are you trying to run 1 wire at a time or a twisted bundle?
4/0 aluminum is pretty flexible especially 1 at a time.
Thanks for the replies. I’ve got some 4/0 aluminum left over from when I built the house so I will use that. I was just hoping there might be an easier way. I don’t have to go far but there is lots of 90s. I will try one wire at a time and see how that goes.
Yeah, 90's are a pain to feed.
It would make it easier if you went 2.5" conduit
