D
Deleted member 9967
Guest
I am curious about something.
I do not have the equipment to do a low balance on lifepo batteries.
Plus is scares me in that if I discharge to low, the batteries will die.
So is a top balance alone ok?
And once done.
Do I do it every time I charge the batteries?
If not, then do I disconnect it or what?
Also how often should I top balance the batteries?
I will be using 8 - 320 Ah lifepo batteries in series in case you need to know.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And once done.
Thank you.
