Bob B
Emperor Of Solar
- Sep 21, 2019
- 9,228
My reasoning is that I cannot find any measurable benefit that is documented.
Let’s assume that there is a 10% increase in some metric although I doubt that.
There have been a few people on the forum who had a 100% loss of at least one new cell trying to top balance and that is fact.
By my simpleton analysis you are risking 100% loss for a potential 10% gain. I just don’t see the benefit.
Just my experience and observations. Here is what I did:
48v LiFePO4 build
For my application I wanted to build a semi-portable system capable of running a 1500w Inverter. Most parts are on the way so here I go. This is also a "proof of concept" thing for me and if I do a second, non-portable install down the road I could easily use the same devices powered by some...diysolarforum.com
My new, well balanced cells have stayed that way with just passive balancing, during charge only, and I cannot imagine why I would want or need to do it differently.
N=1 here but I think it is a very reasonable choice to make.
Hope that helps.
I have seen some of the posts you are describing.
There are a lot of different battery types used. The cells you used are top end cells and may be better matched . Others may be trying to get by with cheaper cells that may require more TLC.
When top balancing taking the cells up in stages .... and using a meter to verify your equipment voltage and being very careful at the top of the range would be the prudent.
