JohnnyBravo
Angler
Hi,
I have 12V 6000W inverter and 3x 12V LiFePO4 different capacity / brand batteries with their max surge current is 100A or 150A for some seconds (based on their specification).
I have 1000W vacuum cleaner that seems it is using about 2200-2600W initial starting spike therefore none of my batteries will support it, the BMS will detect the overload and cut the power.
Questions are:
1. should I buy a 12V high current / starting battery (still LiFePO4) for such application? besides its high current support, what other features/disadvantage I would have using it?
2. do you have other solution for my case rather than buying a 24V inverter and another same type 12V battery?
thank you
Questions are:
thank you
