Hey all. I’ve recently discovered this forum and there are some brilliant people and solutions on here, so I’m hoping someone can help me… my solar installer was useless and didn’t really know what he was doing, so I’m learning all this as I try and figure out the system!
My question is "how can I stop my Eddi from using the batteries to heat the hot water"?
From the 3 images below you can see (at least I think that’s what it’s showing) that in images 1 and 2, you can see that the Eddi has changed it’s mode to “diverting”, but it’s clearly pulling electricity from the battery, and when the diverting stops, the battery state of charge remains level or increases again due to excess solar.
In image 3, it starts with what looks like the excess solar is heating the hot water, and then just after 5pm the batteries are taking over again.
All the data can be seen in the various apps, but I’ve used Home Assistant to pull all this data in so that I can see it all on one graph easily
I wondered if I could setup some sort of Home Assistant routine that if the battery is discharging quickly then change the Eddi mode to “stop” - I have a routine to stop diverting once the tank is about 80% full of hot water anyway, otherwise it just keeps on heating!
I’m sure there must be some sort of setting on either the Eddi or the Inverter to try and stop this happening.
If it helps, the bits that will probably be relevant to this question are:
Thank you for any ideas!
- SolaX X3-Hybrid-G4 (10 kW) inverter (set to “self-use” mode)
- 4 x SolaX batteries (1 x SolaX MC0600 HV10230 V2 (3.1kWh) and 3 x SolaX HV10230 V2 (3.1kWh) = total 12.4kWh
- A MyEnergi Eddi is diverting power to the hot water tank (Mixergy)
- Hot water tank is a Mixergy, and there is a gas boiler attached to it also
- 3-phase power to the house (not sure if it makes a difference)
