Excuse the newbie-to-hybrids question, but I’m hoping someone knows the answer:
Following a power outage when the UPS capability of the hybrid has taken over supplying 120V/240V split-phase power out the AC input and now grid power returns, what physically/electrically happens as the output of the hybrid has to resync to the phase f the grid?
To be more explicit about the steps and my question:
1) Grid Up Hybrid in pass-through - AC put in sync with AC input (through internal transfer switches).
2) Grid goes down (power outage) - transfer switches open as inverter takes over continuing to deliver in-sync split-phase power out AC output (while now isolated from AC input).
3) Sync list during extended power outage - after enough time running independently of (still off) grid, phase of inverter will shift and it will slide into being out of sync with the grid signal / phase.
4) Grid comes back up - reconnect to grid power. When the grid finally comes back up after an extended power outage, the hybrid will recluse the interval transfer switches and will again short AC input to AC output. This is what I am asking about.
For the sake of argument, let’s imagine that the grid signal / phase is 90-degrees or even 180-degrees out of phase with the inverter phase by the time the transfer switches close and AC input carrying grid signal is shorted to AC output.
What happens?
Is there just an abrupt one-time 90-degree of 180-degree phase shift at the AC output and if so, is that harmful to any loads such as refrigerators or any other type?
I’m trying to understand what happens at the AC-output as a hybrid inverter re-syncs to grid after an outage and whether that process can result in any excessive stress or damage to any loads being powered by the hybrid during the outage…
What happens?
