ianganderton Auckland, NZ Joined Nov 8, 2019 Messages 771 Location Auckland, New Zealand Mar 2, 2022 #1 I'm not quite sure what product to use to do this. I want to put a 250A fuse on the battery as close as possible to the +ve terminal. Its an M8 stud terminal as seen in this image
NVS Solar Enthusiast Joined Sep 14, 2021 Messages 370 Mar 3, 2022 #2 You could use a battery mounted fuse block like this. Bay Marine Supply MRBF Terminal Fuse Block Kit (Fuse Included) – Single Stud 5/16" (M8) Compact Marine Rated Battery Fuse 250A https://smile.amazon.com/dp/B07LC3Q4LD/ref=cm_sw_r_apan_glt_i_5YFSBRKVBPCAC3ZBBQZV
ianganderton Auckland, NZ Joined Nov 8, 2019 Messages 771 Location Auckland, New Zealand Mar 3, 2022 #3 NVS said: You could use a battery mounted fuse block like this. Bay Marine Supply MRBF Terminal Fuse Block Kit (Fuse Included) – Single Stud 5/16" (M8) Compact Marine Rated Battery Fuse 250A https://smile.amazon.com/dp/B07LC3Q4LD/ref=cm_sw_r_apan_glt_i_5YFSBRKVBPCAC3ZBBQZV Click to expand... Cool, that’s awesome, thanks. I hadn’t managed to find that solution. Now I know what I’m looking for I think I’ve found them locally (NZ) Blue Sea MRBF Terminal Fuse Block Blue Sea MRBF Terminal Fuse Block www.lusty-blundell.co.nz
