Yes i am in the UK,. how did you know?
I watch a lot of Greg, couldn't find the answer, i'll search again. Thank you
As it is all indoors can you not use 1,5 or 2,5mm2 x 3core PVC flex ( brown , blue & green/yellow ) as it is much nicer to work with / more flexible than twin and earth. Choose cable based on the cct breaker capacity.Do i use Twin and earth / twin core flat or do i use a positive and negative cable to get power from my inverter to the sockets in my van. I am a novice so please excuse me if this is a really dumb question
Joey , would like to see what romex looks like - will google.In North america the goto wire is "romex".
Twin and earth is not a common term.
Ok thank you,
Do i go from inverter to plug then Arctic Blue Wire to (consumer unit) then to sockets
Or do i just go straight to sockets and skip the consumer unit please?
What is the continuous watt rating of your inverter?
Sorry , do not know what that is. Maybe known as something else here in ZAThank you soooo much
Did you use a consumer unit?
