timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 19,423
Grounding is about personnel safety.
Not from the 48v battery. That won't kill you.
Thanks for the input.If something goes wrong inside the inverter. And AC power is conducted to the DC side. And if it finds its way to the battery case. It needs to trip the over current protection, before damage or injury occurs.
I know that it's a lot of if's, but that's what safety is about.
It all comes down to what size breaker you provide for the battery bank as a whole. With 12xEG4 I would only do 400A max personally, so that would drive you to a #2 or #3.What do people ground their 6 battery EG4 racks with?
And most inspectors would likely pass it as well. But, if you want to keep it safe it is best to properly bond things. Given some of the issues people have had with a lot of this equipment I tend to think that extra safety is likely a good idea.I am sure the majority of people do not do this. Or have heard of it.
Grounding and bonding is for people safety.It all comes down to what size breaker you provide for the battery bank as a whole. With 12xEG4 I would only do 400A max personally, so that would drive you to a #2 or #3.
If your 12 EG4's are in two independent racks with a 400A breaker protecting the battery cables then personally I would use a #2 from ground bus to the first rack and feed it through to the second rack. If you needed to install bonding jumpers for each individual battery then they would be #6 to the frame.
Yes and no; bonding is for touch potential, but the way the code works it is also required as an ungrounded system to carry fault current... unless my code interpretation is wrong. For an ungrounded system the first action is to carry fault current, and the second to maintain touch potential.Grounding and bonding is for people safety.
Basically if it's metal, and someone can touch it. It should always be safe to do so. Grounding the metal battery case and metal battery rack, has nothing to do with the battery voltage or amperage. It's for touch safety, against harmful voltages. (Higher voltage AC and DC power) if they were to find their way to any metal parts, that a person could touch.
You are correct about carrying fault current. But it's not for the battery fault current. An ungrounded system above 60v is required to have fault protection on both conductors. Actually all ungrounded conductors, in a system. Fault current on the batteries would be from positive and negative coming together. Not to the case or rack, unless both positive and negative came into contact at the same time. In that case the battery protection (breaker, fuse, BMS) comes into play. Not the grounding or bonding.Yes and no; bonding is for touch potential, but the way the code works it is also required as an ungrounded system to carry fault current... unless my code interpretation is wrong. For an ungrounded system the first action is to carry fault current, and the second to maintain touch potential.
(edit Your interpretation would be 100% correct though with UK standards.
Bothwhat is the proper manner to ground eg4 batteries to chassis in mobile (rv or boat) applications? i am pairing the battery with a samlex evo 4024 and the mobile schematic in the manual has the negative grounded to chassis, does the dedicated ground connection on the eg4 satisfy that requirement? or do i ground both to chassis?
the samlex battery diagram doesnt have a dedicated grounding connection on the battery, it just lists the battery negative grounded to chassis - the eg4 manual says nothing about grounding in mobile applications, just grounding the chassis of the enclosure to the battery rack if you purchased one - i also want to make sure its ok to ground to same bus bar/chassis connection if i am to ground both
If the battery has the mounting flanges installed. You can use a bolt, nut, and star washer. And connect to the flange.This thread never got answered? It was said its on the front but mine is like the picture posted, nothing on the front and I just have one battery no rack... How do I ground the battery?
