Bob B
Emperor Of Solar
- Sep 21, 2019
- 8,648
What I have observed with mine is that if the pack or cell is at a lower SOC when connecting the power supply .... The voltage will drop when connecting it ... Well, unless you are using the crappy alligator clips that comes with these supplies.
The power supply will output it's max or current level that has been set ..... and be in constant current mode. As the pack / cell voltage increases, the power supply will then switch to constant voltage mode and output the voltage that it was adjusted for with no load .... and the current tapers off.
If you attempt to adjust the voltage with the load connected there will be now way to know what the setting actually is .... It will very likely be set too high and when the supply goes to constant voltage mode the pack / cell will be overcharged unless there is a BMS connected for protection.
Hence ... everyone saying ..... ONLY ADJUST THE VOLTAGE WITH THE POWER SUPPLY DISCONNECTED and verify that voltage with a DVM.
