I'm waiting to see how this works for one member. https://diysolarforum.com/threads/i...ts-in-tech-news-or-anything.21064/post-253431I am thinking about getting a ductless mini-split ac but was wonder how many watts of power they use.
I have been looking at 12000 BTU and 18000 BTU 19 to 22 seer.
Has anybody checked power consumption of there unit?
I know this is an older post, but 450w draw from the Midea might meet my needs, I can’t find the video Will did about this unit, and I’m looking for more real world experience on these.I have 2 mini splits, I have the Midea U which the owner of this board just did a video about, it is 15 seer, 10,000 btu, however the most it pulls is 450 watts, thus I can use a standard solar system to power it. The big advantage it has is it is portable, at any time I can move it anywhere, the other 240 V mini split I installed from Serville is forced to stay put, has a seer over 20, and can heat as well as cool. Because the Midea U works so well for me I have been running it here in Florida cooling 3 rooms and it works good enough to be 10 deg cooler than outside, it will use less energy when the room cools off so it does not destroy my batteries energy. Another option is the DC mini splits out there that normally are 48V they cost like an extra thousand more, but the seer rating is far higher. Having the ability to run my Midea off generator and solar is the big selling point for me.
The Midea U is a window air conditioner, they are very good units but designed for sash windows. They can be used in other types of windows, but you will need to make something to seal the window opening. Which is fairly easy to do...I know this is an older post, but 450w draw from the Midea might meet my needs, I can’t find the video Will did about this unit, and I’m looking for more real world experience on these.
Any idea on very rough, seat of pants averages on watts pulled in regular and eco modes?The amount of watts pulled depends on if you have it set on full blast or not...... Hotter days more power required. The most watts I find it pulls is when in dehumidify mode. I am very pleased with it as it is portable, and quiet and so much easier to install than a mini split, but it does not heat which may kill the deal for some.
