I bought and installed myself Mitsubishi hyper heat 42k btu unit with 4 indoor units. If I were to do it again, I would do 2, outdoor units. Better energy usage for my layout vs one big unit. We never had central air (I was tired of window units) and the heat is supper efficient! I went with Mitsubishi because they make the smallest indoor units (6k). I have a smaller house and the bedrooms are really small. Thr 6k are still a bit to big but manageable.
This will be the he second winter coming up but last winter was mild! The efficiency of the a/c was amazing. Even when it was hot out (110* heat index) it was only pulling 9 amps. I’ve seen it higher but that’s when I waited till it was 80* in the house and turned them on to 72*.
We have baseboard electric heaters which I really like, but the mini split are just as nice because you can set the temps in each location too. I felt like it was the warmest the house has ever felt because it was an even heat trough out since it seems to always be running very low. Not the cheapest to buy, but I wanted the name, the -13* heating and small indoor units.
