DIYrich
Solar Wizard
I'm thinking of how to parallel two Sol-ark 15k to increase grid down peak ability. In theory, putting the grid and load lines in parallel is not complex. However, in reviewing connection options, I couldn't find an easy way to connect three 4/0 wires together to handle the 200 amps from grid into each inverter, and combine the Load lines to the Main Service panel.
Is Busbar the option? Crip a connector to 4/0 wire? Same as combining battery wires?
Or, find a connector with 4/0 on the input side, and two 2/0 connections on the Sol-ark side? I'm thinking if any one Sol-ark goes down, I would need 4/0 wire to the Sol-ark to handle the full load.
