Hello, I'm building 2x 48V batteries (each 3P16S using 280ah lifepo4). Each battery will have its own BMS and will be in parallel and connected to the inverters (either MPP or Growatt....still deciding). I know under normal circumstances the 2 batteries will be balanced between each other but my concern is, if something were to happen and I need to take one of the batteries offline, then by the time I'm ready to connect it, it will have a different SOC than the battery that remained online thus causing a potential inrush when they are connected again. Is there a way to deal with the inrush safely?
