Thanks for the info. What do you set your charge voltage/cutoff voltage to. I am still in the processes of finding the best BMS for the price. I have a battery analyzer at work. When I get my first pack assembled I want to run it through some tests.
I'm off-grid with grid-assist on purpose to avoid grid-tie.
My goal from the beginning is *long life* of the powerwall - as in 10, 20 years. After all, it's so much work to build this thing.
Thus, I'm ultimately shooting for 30% average DOD (purple line) but only down to 37% lifetime average DOD so far. I hope this will lead to LifePo4 type cycles - e.g. 6,000-8,000 cycles as shown in this famous Battery University Chart. Hope to prove the charge true!
Operating with 49.5v low (3.54v/cell) and 56v (4.0v/cell) hi. In the winter a typical cycles is 49.5v -> 51-52v hi. In the spring / summer I have enough PV to run 24/7 so it's typically 56v hi every day but only goes down to 52v by next morning. Thus, the overall operating range is 3.54v/cell <---> 4.0v/cell but the daily voltage range is a subset and varies depending on the time of year.
I've arrived at this range based on several local factors including max use of incoming PV, keeping a buffer above the discharge curve knee, long life, consumption profile of my home, and other factors.
You may decide on a different range - perfectly OK as you're situation is unique to you. However, in general, I would recommend staying within 58.1v (4.15v/cell) hi and 47.6v (3.4v/cell) low. The main reason is there just isn't much power from 4.15v/cell -> 4.2v/cell on the top end or 3.0v-3.4v on the lower end but you *greatly* add stress (shorter life) to the cells.
