apctjb
- Jun 16, 2020
- 480
I recently received 32 EVE 280 cells (from Xuba-Amy) and have assembled them in a 2P16S configuration with Chargery 16T BMS. I opted to skip top balancing as resting cell voltages were within 25mv (lowest to highest), I did not have a power supply available and impatient to build after waiting 60 days for my cells
I began charging at a constant 25A (utility power to the inverter/charger). All good until individual cell voltages approached 3.4V when one cell voltage (#16) began to rise faster than other cells. Within a short period of time the highest voltage cell had reached 3.65V while all the others were still in the 3.4V range at which point I stopped charging. Next morning I checked and all cell voltages had dropped to just under 3.4V and the spread between highest/lowest cell was 20mv. Started charging again at 25A and within a short time the "weak?" cell started rising rapidly to 3.6V while the others stayed in the 3.4V range.
Question; What testing can I do to determine if the cell that voltage rises rapidly above 3.4V weak/bad or simply at a higher SOC than the other cells ?
