spitfire6
Hi,Drift I'm gonna have to learn as I go. I think it's gonna be a while of not trusting my SOC calculation since you're basically designing the calculation yourself. Maybe @Ampster has drift setting advice.
I suspect you have a current transformer fitted to the Orion.
The Orion Coulomb counts to calculate SOC. A very good method but errors can add up so drift points & times are available so you can use the non-accurate voltage vs SOC to drift the SOC up/down AKA reset the SOC. it is a forced override of the accurate coulomb counting. I would think carefully before adjusting the curve.
Cheers,
Iain.
