I’ve been searching for / waiting for a 24V hybrid inverter with capability to offset loads on the AC input (grid side) using external CT sensors. This is intended primarily for grid-tied customers with existing AC-coupled solar who are primarily interested in adding a hybrid inverter and a battery for load compensation rather than backup , Luke me (so load compensation on the AC input is a requirement, while support for backup power when the grid gird down is merely a nice-to-have).
Deye / Solark probably set the reference for this capability, but I’m hoping to find a much more budget-friendly option, ideally also supporting a 24VDC.
So I thought II would start this thread to keep a running list of options supporting the Zero Export to External CT Sensor capability as new offerings emerge:
48VDC
Solark / Deye
Outback Skybox
Schneider Conext XW Pro
24VDC
Victron Multiplus II 120x2 & 120 [NOT UL1741, just UL458] (update)
I’m not including Enphase since their AC-coupled battery is not a classic hybrid inverter and it only works within an Enohase-only solution
And I believe the same is more if less true of the Sunny Island (but happy to correct if I am wrong).
This thread is intended to be focused on hybrid inverters that can connect to either/or/both DC-coupled solar as well as AC-coupled solar connected to either the AC input or the AC output with the ability to monitor grid-consumption using external CF sensors and to offset / zero out that consumption by pushing 120VAC or split-phase 240VAC into out into the AC input (US grid only).
There are some new offerings on the cusp of emerging into the US market such as that from Luxpower/Huayu, but I’m going to wait until a few owners in the Forum have reporters on the capability of those inverters before adding them to the list.
48VDC
Solark / Deye
Outback Skybox
24VDC
